F35C Mirror like coating
MelisDoc
Modeling Time User
Che Genere di Modellista?: Aerei, principalmente jet legati alla base di Decimomannu
colori preferiti: Gunze, Tamiya, AK
Nome: Giacomo
Messaggio da MelisDoc »
Foto inserita a scopo di discussione da https://www.facebook.com/share/19ZXd8G ... tid=wwXIfr
Copio e incollo dalla pagina Facebook di un noto modellista/fotografo aeronautico:
“ U.S. Navy F-35C fighters are outfitted with a new, mirror-like reflective coating designed to counter infrared search and track (IRST) systems, enhancing their stealth capabilities. This coating, applied over the standard grey livery, aims to reduce the aircraft's infrared signature and may also impact its radar signature. The coatings have been observed on multiple F-35C aircraft, including those assigned to various squadrons and even on aircraft carriers, suggesting a broader testing program.
Here's a more detailed breakdown:
Purpose:
The primary goal appears to minimize the aircraft's vulnerability to IRST systems, which air-to-air missiles utilize to lock onto targets based on heat signatures.
Coatings:
The coating is described as mirror-like and may be designed to reflect infrared energy, making the aircraft less detectable by IRST sensors.
Application:
The coating seems to be applied in areas that do not interfere with critical components like access panels, weapon bays, and sensors.
Testing:
The Navy has been testing these coatings on multiple F-35C aircraft, including those not assigned to the test and evaluation squadron, suggesting a potential rollout to operational units.
Potential Benefits:
Beyond reducing the IRST signature, the coatings may also offer some advantages regarding radar signature, although this is still under investigation.
Concerns:
Some concerns have been raised about the potential for these coatings to compromise radar signature and their durability in the harsh maritime environment.
Longer-Term Implications:
The use of these coatings may precede future stealth technology enhancements on the F-35 and potentially on future generations of aircraft.
Voi come rendereste questa finitura a specchio sperimentale ? Qualcosa tipo un metallico alclad lucidato?
fearless
Re: F35C Mirror like coating
Messaggio da fearless »
Gli Alclad, ma anche altre marche tipo AK Extreme e MRP, non sono lucidabili, ho fatto delle prove ... C'è la serie Metallic della Gunze e anche delle paste in tubetto della AK che invece sono lucidabili (provate pure questi) ma non è così facile come sembra... Non è facile soprattutto ottenere una finitura così a specchio, devi dare molte mani perché lucidandol troppo porti via la vernice/pasta...
Odio la plastica bianca!!
zaphod
Nome: Massimiliano
Messaggio da zaphod »
Questo F-35 è una sfida continua. Il Chrome Molotow sarebbe un'ottima soluzione, peccato solo che una volta steso non vada più trattato. Bisognerebbe studiare i modellisti che hanno realizzato la Mclaren di F1 del 2007.
Massimiliano.
Si potrebbero utilizzare i vecchi fogli della Bare Metal che sono molto sottili e danno un ottimo effetto specchiato per questo genere di "coating"... il problema è che il rivestimento, sul reale, ha anche una trama che è visibile in diverse condizioni di luce, e quella non saprei propri come poterla riprodurre.
zaphod
Nome: Massimiliano
Starfighter84 ha scritto: 6 maggio 2025, 0:04 Si potrebbero utilizzare i vecchi fogli della Bare Metal che sono molto sottili e danno un ottimo effetto specchiato per questo genere di "coating"... il problema è che il rivestimento, sul reale, ha anche una trama che è visibile in diverse condizioni di luce, e quella non saprei propri come poterla riprodurre.
ma sul Bare Metal poi puoi applicare le decal e il trasparente? Non perde lucentezza?
Massimiliano.
Le decal le puoi applicare direttamente sopra, la superficie è già a specchio.
I trasparenti, sulle finiture cromate, andrebbero comunque evitati. ;)
MelisDoc
Modeling Time User
Nome: Giacomo
Immagino però abbiano uno discreto spessore che darebbe uno scalino rispetto alle zone con verniciatura "classica" grigia da stendere ad aerografo?
MelisDoc ha scritto: 6 maggio 2025, 13:29 [Immagino però abbiano uno discreto spessore che darebbe uno scalino rispetto alle zone con verniciatura "classica" grigia da stendere ad aerografo?
No, pari allo spessore di una decal... prima dell'avvento di sistemi più funzionali, come le vernici Alclad, veniva usati per "wrappare" modelli interi.
Oltretutto la maggior parte delle superfici riflettenti sono "circondate" dalle costolature del rivestimento RAM... quindi l'eventuale spessore verrebbe anche mascherato.
zaphod
Nome: Massimiliano
Starfighter84 ha scritto: 6 maggio 2025, 15:08
non ho mai conosciuto i fogli Bare Metal, sono modellisticamente un bambino di 8 anni, ma erano adesivi?
Massimiliano.
zaphod ha scritto: 6 maggio 2025, 15:21 ma erano adesivi?
Esatto.
QUI un video con qualche modello finito, i fogli hanno diverse tonalità.
Torna a “Lounge Room”
